Marks Web Site
Date:  2-26-2008
Number of Hours:  11.75
Manual Reference:  8-16, 9-3
Brief Description:  Canopy latch and static system installation
I started today by installing the Wd-617 canopy latch tube, the VS-411 bulkhead brackets, C-605 and C-606 links. I also fabricated the C-710 push rod assembly that connects the forward and aft canopy latch mechanism. I also installed the static system ports and the static system manifold and prepared the routing of the static line to the intrument panel area. Lastly I installed the rudder cables.
Wd-617 latch tube, VS-411 brackets and C-605 & C-606 links installed
C-710 push rod
C-710 push rod
Static system ports and maniflod and rudder cable installation
